Hi all.
I have a problem in Zbrush that I can hope you can help me with.
I am using the standard brush with Spray Stroke to add an alpha to my mesh. It is a face where I want to add alphas, but without adding volume. When I add the alphas the volume changes a lot (see picture).
I must have done something wrong, as it only affected the surface at first, but now it is adding a lot of volume each time. It doesnt help to reset the brushes. I hope you can help me (I am new to Zbrush so sorry if the answer is obvious).
Kind Regards
