A Beginners Guide : Zbrush to 3DS Max Pipeline.
@gordon02380
i guess you’re not the only one, it has to do with the vertex order. As someone said (cannot remember now, but credits go to him), in max 2009 you have to import/export twice to avoid that error. That is, import, reUV, export, import again, export again… that worked for me. And if I were you, I would do as few as possible modifications on your mesh or stack in max (of course no new polys whatsoever…). Hope that helps!
Unfortunately that hasn’t worked for me :confused: Thanks for the advice though.
I hope someone comes out with something like this for 3.5R3…my results from using this tutorial came very close (looked like…the texture was rotated slightly between zbrush export and 3ds max import…???)… but close isn’t cutting it unfortunately. :frowning:
thank you very much, i just tried to make an obj into 3dsmax and i had difficulties worked on it, especially getting color and material info from zbrush to 3dsmax. i will surely learn from your guide line.GBU. :smiley:
thank you very much… its really helped a noob like me. a millions thy…:smiley:
Could someone reupload this file please?
Maybe it would be helpful for me.
agree
all the link does’t work anymore, please…
I really appreciate your shared knowledge.
Could you reupload the file?
I need learn this tool.
Thanks again.
reupload please…
Same here reupload…
Just joining in with the above sentiments, re-upload would be awesome!
Oops ***8212; this shared file or folder link has been removed.
Hi Igoreshkin
You can upload the files again please?
Exactly what I was looking for ! I gave up with Zbrush because of all those steps between 3dsmax and Zbrush which where a nightmare.
I’ve decided to dive in in this app again and I found this thread.
Unfortunately all the links are broken :cry:
A re-up maybe? :wink:
hi
i will be be very grateful if the A-Beginners-Guide-Zbrush-to-3DS-Max-Pipeline PDF is uploaded for share as knowledge
thank you for bringing such great info to needy and newbies for your great effort…
thank you all guys for great help for starting learning the zbrush
thank you
sri
keep it up friend
my email
srinu2 (at the rate)excite.com
it’s actually impossibile to download the guide in pdf…broken links? Someone could share it again? I’m curious to read it.
it would be really great if some one gives the links as lifesaver…
thank you all
sri
[email protected]
