I have one more question please, I have a circle object, there is a brush that has a screw and nut head option is there a way to add say 20 nut heads equally spaced around the circle object? Hope this makes sense.
thank you…
Hi again @tom356
Are you using ZBrushCore or the full version of ZBrush? You posted this in the ZBrushCore forum. If you are using the full version of ZBrush then you can post your questions in the Latest ZBrush Usage forum.
To answer your question, you can use Radial Symmetry in the “Transform” menu for that operation (see image below). You will have to enable the “(R)” button for Radial Symmetry. That is the easiest option.
Thank you, worked great.
