ZScript: ZFabric16 works with Z2 (pag.5)
Works fine with Z2…until now…
cameyo
Happy for you :sunglasses:
Pilou
Ps A button who fill a same number in the same line? :slight_smile: (easy :wink:
Here is two demo script to show how works ZFabric…Demo01.zip
Demo02.zip
The first contains some notes.
The second show how to use Stencil with ZFabric (but without notes).
Hope this helps.
I’m working on a new version of ZFabric with LineII Stroke type, Different size of lines, ecc. (the button Pilou request…)
cameyo
Looking forward for the updates Cameyo! You’e
the man!!! :wink:
Thanks froyd, I was aming at some thicker
material to texture interior elements like
sofa, drapes and so. I had to put some extra
efforts to make them seemless again, but it
was worth it. :small_blue_diamond:
sigh, a great script lost in the jungle, ran across it and thought it good to revive.
i have seen your script 2 months ago and since then i searched this forum but had no luck. now i just have found out the search word “fabric”. i am swiss-german speaking so i have searched before for “cloth”, “Pattern generator” and so on.
lucky that i have found your great script again. this script rulez.
keep on coding such great stuff,
daniel
And why not ask your research on the forum? :smiley:
In five minutes somebody found your wish :sunglasses:
Pilou
This script for Zbrush is a excellent. I do alot of texturing by hand for Poser 5 clothes. So I hope this will help with the speed of doing them.
What a great script! Thank you, now we can make carpet! :slight_smile:
Spheric 3D carpet indeed :smiley:
Pilou
thanks alot ill give it a try a little later keep up the ggod work
and stay posotive
After doing VPAINT and HPAINT, I saw paint on background and my object.
But I can’t have control of my object.
My object seems to be freeze.
Something is missing:
I have seen few textures from users…maybe this little tutorial will helps.
The scripts write horiz and vert lines on the canvas.
You can choose colors and number of repetition lines.
The lines are one pixel width. You can change Stroke->Spacing to vary from continue to dotted line.
If a color switch is OFF then that color is skipped, but the relative number of lines will be counted.
Press the “Default” button before drawing !!
Example:
  1. Load script and press the “Default” button to set the standard drawing parameters.
  2. Press vertical “Random” to create random palette color
  3. Write the following Repeat Value for vertical palette: 2-4-4-2-4-4-2-4
  4. Press “VPAINT”
  5. Now Prees “VCol->HCol” button to copy colors from vertical palette vertical to horizontal palette.
  6. Write the following Repeat Value for horizontal palette: 2-2-2-2-2-2-2-2
  7. Toggle settings: H1=ON, H2=OFF, H3=ON, H4=OFF, H5=ON, H6=OFF, H7=ON, H8=OFF
  8. Create new layer (you can erase the layer if you don’t like textures )
  9. Press “HPAINT”
  10. Now Press MATERIAL button and select a material…
  11. … if you don’t like the material selected…press “X” (the shortcut of “Material” button) and select another material.
How can I rotate and move my object at this point ?
Cresus_Digit
Does Fabricworks with Zbrush 3.1?
I dont think so.
I tworks with Zbrush 2.0
Thanks, any update planned, I only have Zbrus 3.1 and think fabric is an usefull pluggin
I will work on it in the weekend…
I will upgrade it toZ3.1
Have a nice day
cameyo
Great news thanks. :+1:
is all i wanted to have a magic script to design me own stocking.
mille gracie,thanks.
Hi there. I’m still a beginner with ZBrush, and am now looking into texturing and painting with it. This script sounds interesting and I wanted to know if there was an update for 3.1 as mentioned in this old thread.
Any progress with this utility? Does it work with current version?
