ZPlace2 Rev.I (updated 29 jan 2005)
Thanks aminuts :slight_smile:
After some works…i don’t add the 3D fractals…almost for now.
I have some other idea to enhance the script, but i need the new infos from Pixologic…maybe after the new upgrade will be out.
Why you don’t post some of your works with ZPlace?
cameyo
@Cameyo or any others :smiley:
Little test with the PureBasic Prog :slight_smile:
For pc User XP, file format exe in 640*480
Have fun exploration :sunglasses:
Pilou
PS if someone want the source use the private message :slight_smile:
More fun of course :roll_eyes:
Pilou
Thanks.
I have decided to develop with…Python…free and very good.
Sorry for PureBasic.
cameyo
Right now i downloadedÂĄ
I have reading your other topic but because i dont understand dont participate. I will practice with this new version. Your zplace is very usefull beside i feel i dont extract from the script all the utilities it has.
Have you made a new guide or documentation wih some examples?
You know? I visit regularly (and i am very interest in Nanomedicine) the nanogalery website and always think in your zplace because i think(i dont know how actually) you can do very intersting molecular or cellular approach with it.
Well, by friend¡ and…thanks again for the update.
Andreseloy
Good choice too (for the fun : Python’s name comes from Monthy Python :slight_smile:
Open Source delight :slight_smile:
Python = Basic Language + Logo + POO
Just a question I don’t see “compilator”, I just see “interpretor” or virtual java/Python machine ? Am I wrong ?
Maybe you can adapt my Funland as first exercice for see the speed of Python :slight_smile:
Have happy coding! :sunglasses:
“Qu’importe le flacon pourvue qu’on ait l’ivresse”
“What imports the bottle provided which one has euphoria”
Pilou
Ps And you can also try to code my “Ultimate Screen Machine” with Python :slight_smile:
Is just a quick test from your Zplace, probably as i commented you prevoiusly if you can make some setup or standard setting from where we can make slight modification will be very helpful
Thanks again
Andreseloy
Thanks!!
I am writing a new help manual…
Pilou: you can make EXE with Python using some libraries (basically you build an exe with the required DLL and your program). Very fast and simple.
Andreseloy: i don’t post often on your works, but you known i always see it.
I’m glad you repost on this forum…:slight_smile:
What do you mean about “standard setting” ?
What you wish for make cellular or molecular approch ?
cameyo
@ Cameyo
I am waiting my Funland Python adaptation for compare :slight_smile:
Pilou
the setting could be something like…the image is from 1.55b ZB practical guidesetting example.jpg
Is just an example
Thanks very much
Andreseloy
ps: i know you see my post, dont care about itÂĄ
… that with the Zplace Andre :slight_smile:
Pilou
cameyo
Pilou posted on the building that I am working on (here http://www.zbrushcentral.com/zbc/showthread.php?t=23945&page=2 have a read to see what I want to do) that your ZPLace would do the work. I have downloaded the zplugin and would like if you have time to poat a quik tut (here or at the building posts) on how to use the ZPlace for the following
bring in a texture
convert texture to > make alpha
open the decobrush tool and draw and redesign the alpha save that design then bring back into z2 be be rotated, scaled, moved etc
Hi Spaceman,
i don’t understand well what you are doing …(it’s my problem, because english is not my native language).
Anyway, here is the Zplace2 manual.
Please, try to explain to me your problem.
Thanks.
cameyo
Il decobrush di Z2’s può torcere l’alfa nelle figure differenti ma una volta che ho la figura io desiderilo non può conservare la figura recentemente generata come ztl. Posso conservare la figura recentemente generata come una struttura o alfa ed allora usare il tasto della moneta dello stampino per muoversi, regolare e ruotare, ecc. Pilou ha detto nell’alberino che ha inviato che il vostro Zplace2 funzionerebbe più meglio allora il decobrush e non conosco come ad esso con il vostro Zplace2. Stavo chiedendo una mini lezione privata su come usare il vostro Zplace2 mentre il decobrush (anziché il decobrush) ed allora posso muoversi, regolare, ruoto, ecc. esso. Se fate fare il tempo tp uno (forse alcuni bloccaggi di schermo che mostrano come a faccialo). Ho usato il babelfish di altavista per tradurre da inglese ad italiano
Cool!
Thanks Cameyo! i amgonna give this newer version a try :):+1:
i just printed and right now reading your manual, thanks a lot friendÂĄ
very appreciated your effort to share everthing you knowÂĄ
Andreseloy
Thanks Massimo you have understanding and the manual fit to all my requerimentsÂĄ The exmples are great and allow to learn, have a model and modifiedÂĄ
Andreseloy
thanks a lot Massimo i am in debt with youÂĄ
Thanks Mario.
You don’t have any debt with me :wink:
I’m very happy that you (and others) use my script.
cameyo
