Thanks, LudikaStyle!
~S.~
~S.~
No prob.
I should teach you how to fish rather than serve you a fish, anyway cut/pasted the page to microsucks Word and printed to PDF with Acrobat so I’m afraid too most of the people doesn’t have both softwares.
A solution could be to setup your browser to print pages with landscape orientation, this way you don’t get images cropped (horizontally), you still have to do some bricolage if the images are split vertically across 2/more pages.
By the way ZBrushCentral is a great place to be, i’m a newbie but getting involved by the enthusiasm of everyone, moderators first!
It’s definitely fun to stroll around the threads
Soon my first ZBrushstrokes!
Federaik aka LudikaStyle
TIMEWARP
Tryed that one, in Firefox Beta 1.5 i set up the printer to landscape paper and the preview of the first page looks fine, GetFirefoxBrowser!!!
I’m having a problem with editing an enlarged end on the second piece of box I added to the fuselage.
I have the proper object and managed to make the first edge loop box that shrunk as a dragged it away. However, the second edge loop expanded. I thoguht I would be able to move the points to edit the size a bit, but even though I am in editing mode and have selected move, all I can do is rotate the darned thing.
Any help would be greatly appreciated.
Is your draw size set to 1 ?
HI,
Yep, I sure am. I have made sure that move is selected, yet the darned thing just rotates. If I select Rotate, it rotates, too, so at least something is working
I was willing to settle for the larger cube size, just to get past that point at continue the tutorial.
I’ll keep trying. So annoying. Thanks!
I get a strange emotion that I want to eat it.
I get a strange emotion that i want to eat it.
Reminds me of marzipan.
Sorry if i said this twice, my internet lags at the moment.
you can Make the Base Cube in Maya (…or other 3d package)
then import it into zbrush
that is great tut for getting start for this amazing pro
thx
Thanks for this tutorial. Much appreciated. Even if one has another 3D application, it’s a real eye-opener to see howt this can be achieved in ZBrush.
On a sidenote: there are several free pdf creators. Like
http://www.primopdf.com/ (they even have an online service)
WinPDF - Create PDF documents and convert documents into PDF format for free
or, for about $30
which converts html directly into pdf
hi!
in the 6th step of the tutorial; when i push “Reconstruct Subdiv” button, notting happens. i mean, literally… can you guess why this is so
I’m actually having the same problem. Since this was made before ZB3, is there any reason to assume that Reconstruct Subdiv does not work in version 3?
In ZBrush 3, simply load the PolyCube.ztl, which is included in the ZTools folder. Go to level 1 and then press Tool>Geometry>Del Higher
Tank you very very much for help with Zbrush3
that’s works when you load the PolyCube.ztl. Great tutorial.
Until I don’t press make polimesh 3d the programm doesn’t allow me to press reconstruction subdivide. When I press reconstruction subdivide the cube changes form! Is it normal?
Please, answer me!
“This function requires the mesh be partially hidden”
perhaps do a minor edit of the original post about step 6 for users of ZB 3.1.
about " In ZBrush 3, simply load the PolyCube.ztl, which is included in the ZTools folder. Go to level 1 and then press Tool>Geometry>Del Higher"
thanks for the tut
aurick will you consider making your tutorial on box modeling into a movie tutorial.
TIA
Reconstruct Subdiv is work in version 3, if turn on button ‘‘EnableUV’’ in menu Tool>Texture.█UA█
