awesome, thanks for these.
Hey Kraken first thanks for sharing this materials they look really good!!! Do you know if they work with z brush 4? im looking for similar Jantins materials since they dont work on zb4 and look AMAZING!!!
Thank again and congrats!!!
@ Borden, great skin shader!!
Can someone please share P^Tās materials again from page 20.
The link is broken.
Sorry found it in matcap library
Does anyone have the adam lewis matcaps? EVERY link is brokenā¦
Thank you, Erklaerbar, for this wonderful material: Iām already imaging its results on the right objects!..But it is too early for me: Iām still learning.
Please give me a piece of information: when I āSave Asā an object as .ZTL, the applied MatCap disappears, and the object is re-loaded with its default RedWax material.
Is this correct, or am I missing something?
Thank you for your help,
Eduardo
you can press āMā on your brush palette and click āfill objectā and then the object is filled with your matcap, however not the matcap itself but only the slot number. So you need to place the matcap first into your startup folder. hope that makes sense
PS: you can also save the project instead of the tool itself, this will maintain everything, including the material
Thank you for your kind, helpful answer!
The more I study ZBrush, more things I discover to be learned!..
Eduardo
Spaceboyā¦
Both sets are PC and Mac in seperate
downloadsā¦
Cheers!!!
ranger0101
FYI, I just realized this recently⦠The hybrid mats I created do work in ZB4. You just have to hit Best render first, then immediately hit your BPR render button. You may want to scale down the Canvas Bump and Canvas Bump Scale settings. They were designed for the AA Half feature, so the textures should be adjusted when using the BPR.
Hi P^t
please help me !
i can't download this material if you can help me please sent a new link
Tnx
where do i find the bpr render?
Hey guys
Im really looking for this matcap
i searched every where but i couldnāt find it
i will really appreciated if some one upload it ⦠thanks
[](javascript:zb_insimg(ā242215ā,ā33.jpgā,1,0))
You are lucky I have a freakish memory for 3d things and terrible for everything else!
Matcap is called Bgen Horror
thank U so much
and thank ur memory
Hereās my el_TaraClay for youā¦made in Zbrush4.
el_TaraClay.zip (48.4 KB)
KrakenCMT, could you please convert your Material Pack2 to PNG Spheres suitable for Sculptris?(I downloaded the Zbrush trial but cant make heads for tails of the program, its gonna take awhile it figure this out)
Or if someone could upload an easy to follow tut start to finish,
begging with making the document 512x512.
really everyone, if they could start making PNG renders, along with their their ,ZMT material packs for Sculptris it would be cool.
(if people are going to flow back and forth between the two they need the mats)
Hereās my 2 cents. Added with this message.
And hereās how it looks on something Iām working on atm:
Hope you enjoy it. Was trying to capture the look of one of Scott Eatonās works, Hephaestus. I donāt think I quite got it, but I liked the result - so here you have it.
TakoGreenClay.zip (261 KB)
Hi guys! On popular resquest hereās my eye shader :
sebcesoir eye shader.zip (252 KB)
