Make1Mesh - plug-in for Zbrush3
GM,
Naming is a tricky issue.
Actually, I was leaning towards asking to append MERGED at the end so if the file is saved with that name to a folder, it could be found close to other saved versions with related names… however, since the filename derives from which ever subtool is active at the time it is saved, that doesn’t make much sense. So, maybe, if it is applied at the beginning, it could then alphabetically mingle with other merged tools saved to disk at other times. :smiley:
In the QuickSave plugin, because of the auto-incrementing of the same filename, I always scoot up to the top of the list to subtool 0 and increment that (then scoot back down to which ever was the active subtool before the save.)
Looking forward to the next version!
Is it possible to make this an option? Checkbox for tag at beginning or end… or something? If it’s a pain then I’d lean toward the end.
Just to chime in on the renaming issue:
You can’t actually do this without saving the file, right? Well, you can get the path of a saved tool by grabbing the [IGetTitle,Tool:Current Tool], so, if you follow Sven’s method and go to the top first, you could use [FileNameAsk to ask the user for a filename at the beginning, appending MERGED to the existing filename (or top subtool name if there’s no path). That would neatly get over any thorny issues of where to save the thing and give the user the option of changing the filename if they wished.
Fantastic Addition! This has been a great help with a recent project
Awesome plugin, thank you very much!
Mesh based Tools take on the name and graphic of thier current SubTool. So to change the name without saving, you simply change the name of the SubTool. Saving a Tool, actually has the side effect of renaming your current SubTool also.
 :warning:  This brings up the odd issue, and better to flesh these things out now.  Which SubTool, would you name the new mesh?  The current SubTool at the time of pressing?  Some new name, defined by the user, requiring an additional step?  Currently, my plug gives it the name of the top-most SubTool, since that is the first to be exported, and the 1 SubTool that can't be re-ordered.  Technically, that is the base SubTool, but beyond not being able to re-order it, I'm not sure what the significance of the base SubTool is.
Given the current feedback, I'll continue to use the "base SubTool's" name, and add "_Merged" at the end.  And as I add the visibility feature in, another plug will be spawed from that, which will Invert the visibility of all the SubTools.  Maybe add modifier buttons to Make1Mesh too, such as Alt+click to export all SubTools reguardless of visibility. (as it is now)  Maybe Shift+click to get a name input box, so you are not forced to accept my renaming.
These strange SubTool dependencies I mentioned, and the fact that you can only Transform (Move/Scale/Rotate) SubTools using the Transpose tool, makes me think that the additional feature of SubTools, is more of a hack, than a well planned out feature.  Why else would it be easier to Transform a Multi-Marker item, than a SubTool?  You can't even drop a Marker on a SubTool position, or use SubTools with my Recall_Info plug-in for positioning.
Don't get me wrong here, I think the addition of SubTools is great, but I wish it worked more like MultiMarker meshes, or regular mesh Tools, when it comes to Transforms.  Give me a gizmo or something other than Transpose! To me, it feels like Tools just bound together in a GUI, and not internally so much.
But reguardless of these issues, it’s way better than not having SubTools.
LEGEND! :+1: :+1:
This is just super great!!!
Thanks a million!
Now if i couk´ld only figure out how to re construct subdivision for my model to export it to light wave.:smiley:
Husse
Hi
great plugin Game Master 770!
Help me a lot
But I had one problem… When I merge the subtools using your plugin and after use the GRpSplit to open the subtools again, all the UV´s are destroyed.
When I try to import the originals UV´s the high subdivision always explode…
Somebody had the same problem? any workaround?
hope you understand my poor english.
Alemar
Awesome script! I’m wondering if anyone has tried to retopologize a merged mesh? I’m having really unfortunate results. When I project the detail from the merged geometry, I get some pretty unwelcome artifacts.
thenade, I have not seen those artifacts…I’ve merged, split off a
section (thanks to the handy polygroups), and re-topo’d a neck/head
without problems. The original piece had something like 16 subtools.
The only thing I did potentially different than you is I deleted parts off
the mesh (by deleting hidden) that I didn’t need for my re-topo <shrugs>
Once I got my lower re-topo geometry, I zprojected it back (at higher res)
onto the original to further reflect the structure of the model. And again,
no special artifacts…maybe a screenshot so others can see if they get
them as well?
cheers.
WailingMonkey
thanks for the plugin … really nice.
it would be nice if the models size would stay the same.
currently the mesh is smaller or bigger after using GrpSplit and exporting the mesh …
Accept also my huge thanks, dear GameMaster!:smiley:
The plugin helps so much.
I am also delighted other famous programmers like Svengali, Marcus and all also participate to improve ZB3.
Thus I hope to overcome my frustration on tackling ZB3…:laughing:
Feel like mergin should be completely remade, so that it could be performed by a single mouseclick after parts are placed perferctly - in a way of boolean operation in other software…
Anatom
Thanks alot!
Exactly what I neede :slight_smile:
I got home, and it worked great for most parts.
However, I was wondering if it is just for me that polypainting is not kept after merging?
My meshes turn colorless, and also without UVs, making me have to export the color as texture and reimport UVs and so on to get color on a mesh that to begin with didnt use textures…
/dubbilan
thank you a lot
Updated to version 1.24
See new thread for info:
http://www.zbrushcentral.com/zbc/showthread.php?p=371262#post371262
P.S. Wish I didn’t have to make a new thread, but after 2 weeks, posts can’t be modified. :confused:
Superb job Game Master! :+1:
You have made this process so effortless for all of us!
It is greatly appriciated :wink:
thank you very much for Game Master 770 two time
