Insert Multi Mesh Repository
Hey guys,
had a new idea for an insert brush that came to me after playing dominos with some friends the other night.
I made all the domino pieces in low poly, so if you want some roundness, you should subdivide a couple times.
I actually made two brushes. A curve brush that draws a line of random domino pieces and one that just inserts
individual ones.
Not sure if they are of any use for anyone, but I thought it was funny and wanted to share, so you can play with it :slight_smile:
cheers!
I had already uploaded a chain brush to this thread, but decided it was just too difficult to use because it was such high-rez. I made a newer low-rez version that can be divided after it’s been drawn. I couldn’t edit my original post, so I had to post the new version here. I also added other chains to the brush. Some vary only slightly, while others are very different. I hope the brush proves to be useful.
https://www.dropbox.com/sh/x5npu8oxh0bio09/Mf5OkTy4eN
Thanks man, those are great!
I want to use those awesome hoses but when I try to load the brush it says I need a new version of Zbrush of 4.42? I just upgraded to Zbrush 4R4? What gives?
Leaf IMM
I hope this works…
A single leaf IMM at low res is about 380 polys, Ive got crease lines on the edges and on the stem so with a couple of divides you should have a smooth leaf!
hope you like it!
you might want to try to go to zplugins> auto updater> check for updates there should be one
Thanks! This is a excellent idea, however it seems this brush is not working as 1 might expect. Can you reupload a V2of this brush, or explain how to orient properly, bend or even prevent the hair from drawing so large, even with a very small brush size?
Handsonmusic, the size of the brush depends how far you zoom in. Here is a screenshot, both hairs were made with the same brushsize.
The hairs are not snapping to other hairs, so snapping is off. Place the single hair, take the endpoint of the curve and move it around.
Hi everyone, here is mine IM brush of a great white shark tooth. hope is usefull for someone! enjoy! :slight_smile:
http://www.arbiadesign.it/download/IM_shark_tooth.zip
Grass Blades Brush Insert Multi Mesh
CLICK HERE TO DOWNLOAD BRUSH
Gear_IMM Curve Mode: Gear_IMM.zip
https://sites.google.com/site/korea2d3d/Gear_IMM.zip?attredirects=0&d=1
Suit Button Curve Mode ASLine: Suit_Button.zip
https://sites.google.com/site/korea2d3d/Suit_Button.zip?attredirects=0&d=1
Great stuff! thank you for sharing
Spines 1.zip (132 KB)Spines 1.zip (132 KB)
You seriously rock. Thank you
Stair and Triangle: Stair.zip
https://sites.google.com/site/korea2d3d/Stair.zip?attredirects=0&d=1
thx for sharing all this great stuff!!!
After seeing the stairs, I suppose tank treads might also work out well with this.
D’oh! I missed the tank tread post a few pages back.
Shoe_laces.zip
https://sites.google.com/site/korea2d3d/Shoe_laces.zip?attredirects=0&d=1
shoe laces look great, thanks for sharing!
