Finished Plugin/ZScript : Marker Master
First , thank you so much,
Second, I have a request… to make the same xyz point center for two mesh, we need to make this like that: make a polymesh save as obj, reload and after placing on the canvas, import (from the import menu), and dowload the second part by pressing add button.
The mesh needs the same sub division level, and after the two shapes are in the same point center. But I think its tricky !
Why we cannot make a shape put a marker make another one on the same marker (why why why)
I love your tool but with this kind of improvement we can do much more butifoul mesh, and also better geometry.
Br
Nicolas
  1. If you are Loading previously saved materials using the Material>Load button then you must make sure you select an unused material in the material palette first, otherwise the loaded material will replace all instances of that material already drawn on the canvas
Thanks for this… i never know this… a big help
Hi all,
Here’s an update:
:large_orange_diamond: Bug fixed that caused slow down in particular circumstances when loading a project or using perspective.
:large_orange_diamond: Edit/Delete message now points to the object making verification easier.
:large_orange_diamond: Auto-marking continues to work after pressing Clear.
(Mods: thanks for updating the link at the start of the thread.)
Great:+1:
-TOXE
HUGE thanks Marcus.
:+1: :+1:
cool two goodies in one day…must be xmas
Thanks Marcus!!
One marker on one coordinated x,y,z, 0,0,0 if you can do that you’re great ! :smiley: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing: :laughing:
A greeat update to a brilliant plugin - many thanks Marcus :+1:small_orange_diamond:+1:small_orange_diamond:+1:
Chris
Thanks for the update ole buddy!
Greetings Marcus, thx for all of your scripts, they are so usefull :wink:
It’s being said again and again but I want to remphasize, this is probably the most useful user-made script for ZBrush yet. Thanks M. One improvement I’d like to see is an easier way to select individual markers for editing. In a complex marker, it can get difficult picking out each object, so there should be some sort of drop down menu maybe? for selecting which you want to edit.
Marcus,
 First off let me say GREAT script. I have not had a reason (up until now) other than testing to give it a go and so far it works great.
Just thought I would check in for a bit of advice. My current project calls for me to position vertebrae in a variety of configurations. I am using your script to multimark all the pieces. The problem is when I go to reposition the individual pieces it calls for me to rotate them. As far as I can tell the rotate function while manipulating marked object positions is completely useless. There seems to be no way to give an exact rotation, for that matter I can not even seem to freely rotate with the mouse with any precision. Is there something I am missing or is rotating an element in a marked object just rough?
bism
i think they are in the transform menu somewhere but you can drag out the x,y,z info bars and use them to rotate more precisely…if that helps ya any.
bism,
Thanks for your comments, :slight_smile: As you have found, with the Group [the MultiMarkers] in Edit mode rotation can be difficult. It is next to impossible to be precise. This is a feature of MultiMarkers, I’m afraid.
The alternative Marker Master method will be tedious for a lot of objects but gives you more precision:
Use the Group button to position your model so that the vertebra you wish to rotate is clearly visible. Press the Store button (so that the markers are aligned correctly). Put the cursor over the vertebra’s marker and press ‘SHIFT+T’. This will put the vertebra into Edit mode. Immediately press Refresh and the vertebra is returned to the group in Transform Rotate mode, with the Gyro showing. You can now rotate it (if you wish using the Info sliders that aminuts mentions above). Make sure you Mark the new position before moving to the next vertebra if you have AutoMarking off.
Verdant,
Thanks for your comments and apologies for the delay in replying. I would like to have introduced a system much as you describe but unfortunately the marker information is not directly available to zscripters. (I do grab it by a rather lengthy workaround for applying perspective but this is just too slow for use in the main script.) Currently the only way to select a marker is by putting the cursor over it.
If you are regularly trying to edit complex groups you might try lowering the Marker Radius slider in the Preferences>Marker palette. That will mean that the marker is only activated when your cursor is very close to it.
Another thing you might try: if you press the Group button the Gyro becomes active for the whole group. Rotate the group so that your different objects are spaced apart as far as is possible. Now press the Transform>Scale button to make the scale Gyro active. You can now enlarge your group so that the objects are easier to distinguish. Make sure you press Store to align the markers before selecting an object for editing.
Marcus,
Thanks for the reply, I will give that a shot. Here is another question for you. Once I create the group and attempt to rotate it, the center of rotation is way off to this side. In other words rotating the whole group becomes difficult. Is there a way to center pivot in a group? Thanks
BTW, again GREAT script.
Marcus,
I guess the rotation point is set to the center of the screen? Seems like this would be hard to alter after the fact. I guess just create the group near the center.
Tried the directions for altering the rotation of a group element and I think it works fine though I am having some other issue where the object disappears. I will get back to you when I figure out what is going on. Thanks again .
bism,
The center of rotation of a multimarkers object is always the first marked object. In the case of Marker Master this is the MMcenter which is placed in the center of the canvas. (There is also a ‘feature’ of MultiMarkers where the first marked object disappears when transforming with the Gyro; it is partly to overcome this that I use the MMcenter in the plugin.) So yes, it is best to assemble your object around the center of the canvas.
You can edit the MMcenter position (and therefore the center of rotation) but it must be done in Group Edit mode. You’ll need to have a rough idea where the MMcenter is as all you’ll get is a red pivot point when the cursor is close. With Edit on, press the Move button then placing your cursor close to (but NOT on) the MMcenter red pivot point drag it to the position you want. When you’re done be sure to press the Store button.
If you are losing objects then most likely you are forgetting to mark them.
Marcus,
Ok I have changed the center of rotation for the group and am able to rotate objects individually. The disappear problem went away after restarting ZB. Thanks again for the help.
Some great things in this script that I think all scripts should have
-Simplistic interface
-Well commented
-Well formatted msgs
-Use of images in Status msgs and errors
-Clear warnings
Thanks again.
WOOPS,
I figured out why stuff was disappearing. When I go into edit mode the simple brush was selected. I had to reselect the geometry I wanted to work on. Then it works fine. Seemed to swap to simple brush by itself though?
